GN Espace Ocean Chef 3
A very lightly used Ocean Chef 3 cooker is for sale and pickup in Blackburn for $2,500.
The previous owner of our boat only installed in in 2015, but predominantly used bbq on board or an induction top they added. Thus, the cooker has been very lightly used and is in near new condition. We opted to switch to induction.
The Ocean Chef 3 is the big brother of the GN Espace Levante. The Levante 3 burner retails for ~$6,000. I believe the only way to purchase a new Ocean Chef is directly from GN Espace with the associated shipping/import costs.
The Ocean Chef is incredibly well reviewed. The brochure for the GN Espace cookers is here: https://gn-espace.com/wp-content/upl...e-Brochure.pdf
The details of the stove are:
-50cm wide standard cooker
-Gimballed single cavity LPG (Propane/Butane) cooker
-High efficiency hob burners. Fast heat-up and increased turn-down rate for lower flame
-Stainless steel pan support. Secured
-Sturdy removable sea-rail hob surround and adjustable pan clamps
-Glass door option
-Door and harbour locks
-Full width grill
-Thermostatically controlled oven
-Easy clean stainless steel oven interior
-Anti-tip oven shelves designed to securely hold GN cookware. 1 x GN 2/3 tray, 1 x wire trivet, 1 x wire shelf. Dual shelf system for Gastronorm or standard cookware
-Gas safety thermocouple for hob, grill and oven
-Push button ignition. Battery powered 1.5V
-Marine grade stainless steel construction
-Weight: 30.5kg (34.5kg including accessories)
-Made in the UK. CE approved
-Appliance dimensions: W50cm H48.7cm D47cm
-Installation dimensions standard: W54cm H55cm D55cm
